Amalie Green Elixir Synthetic Blend Calcium Sulfonate Grease
Оф. страница продукта http://www.amalie.com/Grease/Elixir-Syn ... ase/NLGI-2
Оф.допуск для ступичных подшипников NLGI GC-LB https://www.nlgi.org/certifications/pro ... ucts/?fl=a
Amalie Greases1.png (840.04 КБ) 12179 просмотров
Amalie Greases2.png (426.7 КБ) 12179 просмотров
Описание на оригинальном языке
Amalie Green Elixir is a heavy-duty extreme pressure grease exhibiting outstanding film strength and resistance to corrosive saltwater environments. With a Timken OK load of 65 lbs. Amalie Green Elixir is recommended for the most severe applications in off-highway construction and mining equipment. Exhibiting excellent water
repellency, oxidation resistance and a wide operating temperature range, Amalie Green Elixir is also an obvious choice for virtually any multipurpose or extreme pressure application. Amalie Green Elixir meets and exceeds the demanding automotive and industrial testing requirements of ASTM D 4950, earning it the GC-LB classification by the National Lubricating Grease Institute. Amalie Green Elixir is recommended for use in automotive as well as heavy duty applications in the construction, mining, agricultural, logging and hauling industries and anyplace where a shear stable, high load carrying corrosion resistant grease is required.
Benefits:
Wide Temperature Range – Amalie Green Elixir has a dropping point of over 570+ F, allowing it to perform across a wide temperature range.
Adhesive and Cohesive – Amalie Green Elixir has a special gellation thickener providing natural tackiness and preventing moisture and other corrosive materials from reaching critical parts.
High Load Carrying Capacity – Amalie Green Elixir is formulated with specialized additives, giving it a Timken OK load of 65 lbs. to prevent wear in the most demanding heavily loaded applications.
10 OZ = 400 гр туба = 160-68342-94, 6834294
35LB = 160-68344-28, 6834428
mikhail-bar
Сообщение mikhail-bar »
Нижний предел температуры -18 (запрашивал у производителя) перечеркивает все плюсы.
mikhail-bar писал(а): ↑30 авг 2017, 10:03Нижний предел температуры -18 (запрашивал у производителя) перечеркивает все плюсы.
нижний предел не стоит воспринимать как такую границу у моторного масла
подшипник ролика или ступичный вполне себе может нормально работать пока смазка застывшая
по мере движения/прогрева двигателя подшипник прогревается и смазка с сепаратора плавится и попадает на дорожку
ничего критичного
mikhail-bar
Спасибо. Можно еще вопрос - на шрусе пыльники выдержат?
drakon8000
Авто: Toyota Mark2
Сообщение drakon8000 »
Эта смазка Amalie Green Elixir Synthetic Blend Calcium Sulfonate Grease в интернет-магазинах редко бывает, всего один раз видел на эмексе, и то сейчас нету.
Если кому надо - покупал себе и товарищу у дистрибьютера Amalie тута
артикул:
1606834294
Пока использовал только для смазки дверей в авто. )
Удивило, что разница между Amalie Green Elixir Synthetic Blend Calcium Sulfonate Grease по сравнению с той же литиевой Castrol LMX очень заметная.
Кастрол вымывается быстро и через год и петли начинают поскрипывать, приходится докладывать Кастрол.
А вот Амали Эликсир со временем так не вымывается. От него отмыться даже трудно, прилипучий какойто.
Вот думаю в ступичные конусные подшипники надо бы смазку посовременне заложить, для этого в первую очередь и прикупил.
Отправлено спустя 2 дня 18 часов 21 минуту 47 секунд:
Запросил у производителя на официальном сайте нижнюю границу рабочей температуры. Потому как ни в описании ни на упаковке нижняя температура не указана.
Ответили, что рабочая температура от -18°С до +246°С в любых подшипниках. И обещают включить эту информацию в обновленные спецификации.
Вот их ответ:
Thank you for taking the time to visit our AMALIE Website and for filling out the “Contact Us” page. Our AMALIE Elixir Synthetic Blend Calcium Sulfonate Grease can be used for wide temperature ranges and has a dropping point of over 570°F. The AMALIE Elixir Syn-Blend is capable of operating in temperatures from minus 18 to 246 degrees Celsius (0 – 475°F) and offers outstanding protection for all types of bearings which includes but is not limited to: trailer, truck, passenger car and heavy duty wheel bearings. We are currently in the process of updating our AMALIE Website and AMALIE specification sheets, I will make a recommendation to our technical department to include operating temperatures for our greases for future reference. Thank you for purchasing our quality AMALIE Lubricants, please let me know if you have any additional questions or questions on any of our other AMALIE products offered.
Best Regards,
Austin Burdick
Customer Support Coordinator
AMALIE OIL COMPANY
PS. Температурный диапазон отличный, нижняя граница почти такая же как у многих литиевых смазок (-20°С у литиевых), а вот верхняя значительно лучше чем у литиевых (+160°С у литиевых)
drakon8000
Авто: Toyota Mark2
Вопрос - нормально ли, что в смазке появилась какаято зеленая жидкая фракция, на фото видно ярко-зеленого цвета. Сначала всё было однородным.
Или это особенность кальций-сульфонатных смазок?
Вот думаю теперь мазать ли с Амали ступичные или намазать классическую литиевую например от Петро-Канады.
drakon8000, может долго хранил ? на вид 2-3 года )
drakon8000
Авто: Toyota Mark2
Gubkin писал(а): ↑22 апр 2019, 21:03 drakon8000, может долго хранил ? на вид 2-3 года )
хранится не долго, с год.
Да и даже если года 3-4, то я полагаю не должно портиться ничего.
drakon8000
Авто: Toyota Mark2
Сделал запрос правильного MSDS у америкосов на оф сайте Amali.
Потому как у них на сайте выложен неправильный MSDS от совсем другой смазки.
Америкосы прислали "правильный" MSDS, причём свеженький, с ревизией за 20 мая 2019г. как будто только после моего запроса спохватились его сделать.
Обещали со временем заменить MSDS на правильный, на сайте.
Amalie Elixir.pdf
(156.57 КБ) 865 скачиваний
Вернуться в «Смазки ступичных подшипников»
