Исследования масел, документация, бюллетени
Добавлено: 12 сен 2018, 14:24
А вот если сводим энергии активации в одну табличку - то абсолютно не очевидно что "чем гуже жижа тем выше нужно портатить энергии (темпаратуры)" Отправлено спустя 1 час 12 минут 18 секунд:Бозон Хиггса писал(а): ↑04 сен 2018, 21:28 как видно что чем гуже жижа тем выше нужно портатить энергии (температуры) для того чтобы началось разрушение (крекинг). Тут указаны энергии для одного моль вещества
Oxidation stability of lubricating base oils
A.Y. El-Naggara,b, R. A. El-Adlya,b, T. A. Altalhia, A. Alhadhramia, F. Modatherc
, M. A. Ebiadb, and A. Salemb a hemistry department, Science Faculty, Taif University, Kingdom of Saudi Arabia.;
Egyptian Petroleum Research Institute, Nasr City, Cairo, Egypt.; c
Faculty of Science, Al-Azher University, Assuit branch, Egypt.
Ближневосточные товарищи пытали три минеральных масла разной KV100 с почти одинаковым индексом вязкости
Oxidation characteristic of base oils under investigation was carried out according to modified ASTM D943. The tested samples were oxidized at 150°C using copper coil as catalyst and flow rate 5 liter per hours for 50, 100 and 150 hours. After testing, the density, viscosities at 400C and 100°C, total acid number (TAN) and flash point of the tested oil samples were determined using ASTM methods D 1480, D 445, D 664 and D 92, respectively. The rate of oxidation was measured by the increase in total acid number and viscosity
e OIL.jpg[/attachment]
Как то вдруг и совсем неожиданно оказалось что
Oxidized base oil designated B3 is characterized by the having high viscosity, carbon residue, sludge content, flash point and total acid number, while base oil B2 has medium values of these characteristics, but base oil B1 is characterized by having high evaporation loss and low values of total acid number. The results obtained from determining the total acid number indicates that the thermal stability of base oils decrease with increase the heavy ends. In general, total acid number increased with increasing oxidation time.
Heavy oil has the lowest percentages of paraffinic hydrocarbons compared with the other light and middle lubricating oils which decrease with increasing interval times of oxidation
Т.е почему то более жидкая по KV100 база имеет большую анти окислительную способность.. Привет поклонникам малого NOACK и высокой FP из Египта и Саудовской Аравии
