Оф.страница продукта http://www.amalie.com/Grease/BLUE-HI-TE ... 0-68321-91
Официальный допуск NLGI GC-LB https://www.nlgi.org/certifications/pro ... ucts/?fl=a
MSDS
Применение в оригинальной версии
Amalie Blue Hi-Temp Grease is a premium, multipurpose automotive/truck chassis and bearing lithium complex lubricant meeting the NLGI GC/LB performance target. Applicable in a variety of automotive and industrial uses requiring extreme pressure protection, oxidation, inhibition, water resistance, and anti-rust properties, including; disc brakes, wheel bearings, chassis, ball-joints, 5th wheels and others. This popular grease is a lithium complex and is formulated with highly refined base oil and specialty additives to meet severe requirements of machinery. This grease is capable of operations from minus 40 degrees F to 350 degrees F, but with a dropping point of more than 500 F. Key features are: • Excellent mechanical stabily – resists thinning or hardening in bearings, minimizing leakage and maintaining extended service life. • Very good oxidation and corrosion protection – via specialty additives minimizes chemical deterioration over extended periods of storage and service. Protects steel and copper alloy bearings against rust and corrosion. • Outstanding Extreme Pressure Protection – provides effective wear protection for ball joints, drive shafts and other parts subjected to high pressure and shock loading. • Wide temperature Operation – offers excellent low temperature pumpability (-40 F) and high temperature (350 F) protection. • Excellent Water Resistance – effectively resists washout and excessive dilution by water, assuring allweather lubrication. In general, recommended for extended service in heavy-duty automotive, truck, buses, farm tractors, construction equipment, high temp wheel bearings (disc brakes), roller and ball bearings, electric motor bearings, throw-out bearings, universal joints, chassis, fifth wheel and many others. This grease is suitable for medium size high speed bearings. It is robust multipurpose grease for a wide range of applications.
35 LB = 160-68324-28, 6832428
4 LB = 160-68327-88, 6832788
14 OZ = 400 гр = 160-68321-91, 6832191
1 LB = 160-68326-93, 6832693
Amalie BLUE HI-TEMP GREASE NLGI2
Вернуться в «Смазки ступичных подшипников»
